Gigabit Lan PCI Adapter Problems?
Aignix
11
First, i have a Asus P8H67 Mobo, Trying Gigabit Lan PCI Adapter Rc 400. I tried plugging in the NIC and nothing. Pc wont boot. Will spin up and light up for just a split second and then it will stop. if i leave it for a moment it will try again. my onboard NIC died so i am trying a new path rather than new mobo of new onboard,I'm not so good with a iron.
I was able to un-select it myself. In any case, it might be that the adapter is defective. Did the PC not boot up while the lan adapter installed in the other slot as well?
It seems kind of strange the computer wouldn't boot up with just another PCI slot being used up. even if there aren't any drivers installed that wouldn't make a difference.
yes and yes. i tried my buddies network card .worked and my network card worked on his. also when i place it in pci slot and plug in cable it lights up. don't know if that will help.
