Gigabit wired network, going wireless N. Ethernet bottleneck?
amorphous_snake
9
I have a wired gigabit wired network at my place connected to an ancient 3com wireless G router. I was thinking to upgrade to wireless N. My question is: most available wireless N routers or access points have ethernet, will this be a bottleneck in my connection, if say I want to run 1080p video stored on one of the wired computers through a wireless device (e.g. a laptop or a Raspberry Pi)?
It really is going to depend what codec you are using. If you send uncompressed blueray data then it takes a lot...still well under 40m. Most other HD streams are 3-4m so they don't put any burden on wireless or even fast ethernet.
For whatever reason 802.11ac is not some huge multiple faster than 802.11n when tested in real environments. Even 802.11n comes nowhere close to the 450m that is advertised. The only place you can get these magic numbers is in some controlled lab. There is no way to even predict how well it will work in your house.
The biggest issue with streaming video over wireless is not how fast you can transmit the data it is the how much interference you have. If you get random burst of interference it will still destroy the data no matter the rate you transmit at.
