gigabtye 990fxa ud3 system fan connector ????
zudotekari
6
Hi, I have a question. I already bought a case model Corsair 760T and I'm planning to get gabtye 990fxa ud3 mobo. I noticed that it only has 2 system fans (1 & 2 and pwr fan). How can I use the 2 front fans and the rear one if it only has 2 system fan? Do I sue the pwr fan? is there a specific connected I need to utilize all fans???
You can utilise a fan splitter. this is a cable which allows you to connect 2 case fans to one sys_fan header on your motherboard. That can accommodate two fans per sys_fan header. The rest of the fans can be connected to the power supply via a fan-molex adapter. Note that the fans connected to motherboard, you can control the speed of them provided your motherboard sys_fan has 4 pins. The fans connected to the PSU will run at 100% all the time
Example of fan splitter: http://www.amazon.co.uk/Akasa-AK-CBFA04-15-Splitter-Cable-Fans/dp/B005FWXWPS/ref=sr_1_1?ie=UTF8&qid=1443646224&sr=8-1&keywords=fan+splitter
Example of molex-fan adapter...
Example of molex-fan adapter: http://www.amazon.co.uk/BitFenix-20cm-Molex-3-Pin-Adapter/dp/B004UL84QC/ref=sr_1_4?ie=UTF8&qid=1443646257&sr=8-4&keywords=fan+to+molex
