While playing a game the GPU fan speed goes up to 4500 rpm for a few seconds and then back to 2500 rpm. Somehow the card gets hot very quickly and never goes below 40 C. I tried to use MSI afterburn for a fan curve, but it seems the fan speed monitoring is locked. It might be linked to bad air flow but i couldn't find similar problems online for other people having the same case. Furthermore i noticed the 4500 RPM only occur if the heat goes over 80 C. Which again seems strange because none of the people reviewing the GPU have had similar temperatures. It also happens in many games whether i play on low or high fps. (e.g.: World of Warcraft 60 fps has the same effect as on 144fps) In addition i have checked if everything was plugged in properly and couldn't find any mistakes made.
My setup:
-be quiet! STRAIGHT POWER11 CM 650W ATX24
-Enermax Liqmax II 240 AMD AM4 Version
-D416GB 2666-16 Fury Black K2 KHX
-GiBy8GB D6 RTX 2070 Gaming OC 8G
-GAM NVIDIA BF V oder ANTHEM DC
-SSD 500GB 2.3/3.4G 970 EVO PCIe M.2 SAM
-Intel Core i9-9900K 3600 1151V2 TRAY
-MSI Z390-A PRO Z390
-be quiet! SILENT BASE 601 Window bk ATX
Thanks in advance and kind regards.
P.S.: help me fix this airport simulating GPU pls 😀
My setup:
