Hello
I have a gigabyte 6850 HD graphics card, its not under warranty anymore. its cooling fans are almost dead and I'm looking for replacement, they are 2 pin fans.
i looked for replacement but I only found 3 pin fans (they are the same type of fans, the connecting pins are not the same.)
Are there any adapters of any kind that i can use to connect the 3 pin fans to my graphics card?
This is my current fans
http://www.aliexpress.com/item/EVERFLOW-T128010SM-75mm-Graphics-Card-VGA-Cooler-Fan-Replacement-12V-0-20A-2Wire-for-GTX460/591901845.html
This is all i could find:
http://www.aliexpress.com/item/Specials-Gigabyte-GTX580-graphics-card-fan-EVERFLOW-T128010SM-0-20A-silent-fan/662215634.html
As you can see they are the same type, but with different connectors.
