gigabyte 7870ghz oc windofrce 3x gpu-z power issue like 12v etc plz help !
shahjiee
9
hi,
i need your help guyz !
today i noticed in gpu-z that when my gpu is running @ 0 % load its power is 11.72v
when i run crysis 3 @ 98 % of gpu load its gone in -72.00v
is it ok ?? or my power supply fault ?
my pc specs :
core i3 2100
8gb 1333mhz ram
mobo asus p8h61-mlx b3
gigabyte 7870ghz oc windforce 3x
corsair gs600 watts
super combo drive hp
wd 500gb caviar blue
1 branded fan which is directly connected to power supply !
my english is not good sry and plz help me
here are some pictures taken from gpu-z
yes in battle field 3 some times my fps drop to 25 to 30 and there is no difference in fps when i change it from ultra with 4xmsaa to High settings !
im playing battle field 4 as well but single player mod and im getting fps upto 55 with out AA @ 1600x900
my driver is upto date latest amd beta and i have already checked the stable one but there is no difference in fps !
Try using an older version of GPUZ or changing drivers because GPUZ is reading or reporting incorrectly.
This is a software problem, there's nothing wrong with the card-if it were getting -72 volts it would not work.
Are you playing BF3 in single player or multiplayer?
Turn AA down, or off, it's reducing your frame rate by at least 25%.
bro ur right its gpu-z fualt showing me in - volts and yes im playing bf3 multiplayer my fps dont increase when i switch my settings from ultra 4xmsaa to ultra with out aa or to High ! if i change it to medium or low then fps increase !
and some time my pc display is gone ! few hours ago my pc was running ok i was browsing and then it gives no display then i restart my pc then it is giving display
i haven't use radeon for a very long time. also such parameter are not exist with geforce gpu when running gpu-z. as long as your gpu working right with games then it should be fine. about that black screen issue it could be a glitch but if it happen from time to time that could be another problem
