Hello!
My problems with a Gigabyte 7970 started about two weeks ago, while surfing the internet, pixels started to flash randomly on the screen and about 1 min later PC got completly freezed and screen turned black (no signal) or completly white/green. This problem has occurred about 10 times in 2 weeks (now this happens not as often as before). Once, instead of pixel flashing, there was screen flickering, and after that PC freeze with white screen.
Anyway, I saw, that the weird artifacts are often apperaing after BSODs - when PC crashes and resets itself, the artifacts are appearing in BIOS screen. It's like a concidance, because I'm getting much BSODs, average 1x per day, because of incompability of sound card drivers (but that's not a problem)
My PC Specs:
CPU - i5 2400s
GPU - Gigabyte 7970 OC
MOBOs - Gigabyte ga-b75m-d3h, MSI B75MA-P45
PSUs - ModeCom Volcano 650W, OCZ StealthXStream 500W
RAMs - 4GB 1333, 8GB 1333
OS: Windows 7 64bit
I decided check the 7970 on other components, so I've tested second MOBO, PSU and RAMs...
I got an idea to make some manually initiated crash BSODs with ctrl+ScrollLock registery method. But, the artifacts it Bios were still appearing on all other components. Those artifacts in BIOS are appearing like 1 per 10 BSODs. After that I can't boot PC normally, only via Safe MOde, because I'm getting glitched BIOS. I've made some pictures to show the problem.
Also, I've checked my old HD 6970 with manually initiaded BSODs, but there were no artifacts.
I've also checked the 7970 with OCCT by 8h Error Checking test - but there were no errors and temps were fine... I didn't get any artifacts in gaming.
I'm confused, because I wanted to sell this card before the problems stared to appear. It works completly fine, but those artifacts in BIOS after BSODs and pixel flashing crashes (but this problem didn't appeared in 4 days) are worryring me.
I know this problem is pretty weird and it won't be too easy to help me. But is there a possibility, that it's not a problem with a GPU? I didn't tested any other versions of drivers (I'm using OMEGA 14.12), but I think, it's not a driver problem if the graphical glitches appears in BIOS, right?
I have even checked that 7970 with a Gigabyte GA-MA790FXT-UD5P with AMD Phenom x4 965 BE, but I couldn't get any artifacts by manually BSODing the PC... Werid.
I send You some photos, ignore the Polish language
In BIOS:
http://www.mediafire.com/view/ntf7rac2awy2lun/DSCF5310.JPG
In safe mode, it looks like this:
http://www.mediafire.com/view/unxirjw0775vglc/DSCF5308.JPG
http://www.mediafire.com/view/7mzd94sbtba3pyq/DSCF5309.JPG
BSOD after BSOD, when I try to enter Windows not via Safe Mode:
http://www.mediafire.com/view/6bz57h9ol4tgr4p/DSCF5312.JPG
BlueScreenView code:
http://www.mediafire.com/view/jz1hplmjde1kx61/BSOD.png
I don't have any photos of pixel flashing. I tried to capture them with Print Screen, but there weren't any artifacting pixel flashes on the image. Is that normal?
I'm sorry for my not-so-good English 😉
My PC Specs:
CPU - i5 2400s
OS: Windows 7 64bit
In BIOS:
