so weirdest thing has been happening for, what i thought, was the easiest part on a graphics card to run. so i got this card for christmas and to be clear this is NOT the G1 by GIGABYTE but the Xtreme gaming 980ti. enough rambling.. so i install this into my new build and all is good and i install OC guru II and the RGB slider thingy is there and obviously allows me to change the "windforce" logo and halo rings to what ever color i want but unfortunately if you have read up on this card there is a little itty bitty button you can press that changes the card to "xtreme mode" and so i did that as well as plugging in the third 6 pin gpu power cord and i boot up.. my card is going through the whole spectrum of colors. so i say "no big deal ill change it" i get into OC guru and find my self with a OC guru with out a RGB section , so i go through the usual of checking if everything is up to date and all that and still to no luck that RGB section isnt there. so then i reinstall my GPU driver as well as OC guru and still nothing but the stupid obnoxious slide show of colors. so any help would be greatly appreciated. as of this publish i dont have OC guru installed. thanks for your time in advance
