Gigabyte AB 350 Gaming, Issue : NO ambient LED
manish9009
Hello all
I just assembled my first ryzen build.
everything seems to be working fine. But due to some reason ambient LED on the motherboard is not working.
I have attached a pic of which area I am referring to,
ibb.co/kOevZR
Thanks In advance.
This is the GA-AB350-Gaming 3?
If RGB fusion in BIOS Peripherals page doesn't help you then there may be an issue with that LED section of the board if it won't light up at all. There is nothing to plug in, that's something that you'd have to do with things like LED strips you buy separate.
- Did you install the RGB Fusion utility from your motherboard support page and try using it to configure your motherboard lights?
- Did you install the latest chipset drivers?
Both of these are found on your motherboard's support page on the Gigabyte website.
Yes I did, Turning On/Off from RGB fusion Makes no difference
Updated Latest BIOS(F10), Latest chip-set
My computer is working fine so I am quite contused If didn't plug something correctly.
Also after googling I found there used to be Ambient LED control in BIOS>
But Now there is only RGB fusion which is useless so far.
