so I have the b450 gigabyte aorus pro wifi motherboard and im trying to figure out if my corsair force series mp510 240gb m.2 SSD can go into my motherboard and what slot will it go into my first build by the way
i have but im still confused on where to put itHave you looked at the manufacturers support site or the manual for the motherboard?
oh okay so dont plug it in the M2B??As always, go to the manufacturer:
https://www.gigabyte.com/Motherboard/B450-AORUS-PRO-WIFI-rev-1x/sp#sp
That Corsair drive is a PCIe 3.0 x4.
https://www.corsair.com/us/en/Categ...2-SSDs/Force-Series-MP510/p/CSSD-F1920GBMP510
The motherboard has 2x M.2 ports.
You want to put that drive in the M2A slot.
- 1 x M.2 connector (Socket 3, M key, type 2242/2260/2280/22110 SATA and PCIe 3.0 x4/x2 SSD support) (M2A_SOCKET)
- 1 x M.2 connector (Socket 3, M key, type 2242/2260/2280 PCIe 3.0 x2 SSD support)(M2B_SOCKET)
I'll leave it to you to look in the manual to determine which one that is.
What do you mean by "messed up"?whoops thats why its messed up thank you so much
like i plugged it in the M2B and i can't find it in my storage but it says its onlineWhat do you mean by "messed up"?
okay ill let you know what happens when i plug it in the M2A
- Plug it into the M2A.
- "can't find it"....? Where are you looking? Is the OS already installed on some other drive?
and windows is on my hard drive but i have a software to move it to the ssd
Hold that thought...😉and windows is on my hard drive but i have a software to move it to the ssd
well when i look up the devices i see letter D and letter C on C is my hard drive and i do believe on D is my ssd but when i try to move windows to it it says that the drive cannot be found...yes the new drive is 240GB and on my hard drive i only have 80 on itHold that thought...😉
The new SSD not being "visible" is almost certainly just because it is not formatted, and has no drive letter.
But...for cloning from the HDD to this new drive...a few questions first:
The new SSD is 240GB?
How much space is consumed on the current HDD?
Please show us a screencap of your Disk Management window.well when i look up the devices i see letter D and letter C on C is my hard drive and i do believe on D is my ssd but when i try to move windows to it it says that the drive cannot be found...yes the new drive is 240GB and on my hard drive i only have 80 on it
View: https://messithygod10.imgur.com/all/Please show us a screencap of your Disk Management window.
Upload your pic to imgur.com, post the link here.
And this is what we out here see:tap the "the picture" thats the link
i still need to move the ssd to the M2A right??-----------------------------
Specific steps for a successful clone operation:
Verify the actual used space on the current drive is significantly below the size of the new SSD
Both drives must be the same partitioning scheme, either MBR or GPT
Download and install Macrium Reflect (or Samsung Data Migration, if a Samsung target SSD)
If you are cloning from a SATA drive to PCIe/NVMe, you may need to install the relevant driver for this new NVMe/PCIe drive.
Power off
Disconnect ALL drives except the current C and the new SSD
Power up
Verify the system boots with ONLY the current "C drive" connected.
If not, we have to fix that first.
Run the Macrium Reflect (or Samsung Data Migration)
Select ALL the partitions on the existing C drive
[Ignore this section if using the SDM. It does this automatically]
If you are going from a smaller drive to a larger, by default, the target partition size will be the same as the Source. You probably don't want that
You can manipulate the size of the partitions on the target (larger)drive
Click on "Cloned Partition Properties", and you can specify the resulting partition size, to even include the whole thing
[/end ignore]
Click the 'Clone' button
Wait until it is done
When it finishes, power off
Disconnect ALL drives except for the new SSD. This is not optional.
This is to allow the system to try to boot from ONLY the SSD
(swapping cables is irrelevant with NVMe drives, but DO disconnect the old drive for this next part)
Swap the SATA cables around so that the new drive is connected to the same SATA port as the old drive
Power up, and verify the BIOS boot order
If good, continue the power up
It should boot from the new drive, just like the old drive.
Maybe reboot a time or two, just to make sure.
If it works, and it should, all is good.
Later, reconnect the old drive and wipe all partitions on it.
This will probably require the commandline diskpart function, and the clean command.
Ask questions if anything is unclear.
Yes.i still need to move the ssd to the M2A right??
