Question Gigabyte Aorus Pro AX Z490 VGA Light
RickJamesBish
8
Motherboard: Gigabyte Aorus Pro AX Z490 (bios F20a)
GPU: EVGA RTX 3070 XC3 Ultra
Issue: VGA Light on motherboard lit and remains lit after cold start but turns off after reboot
All drivers current. The system seems to be working correctly once booted up, besides the VGA LED being lit.
When I power on, the system seems to almost go into a temporary sleep. The keyboard lights initially and system fans come on. The monitor does not display. The key board goes out as do the fans. The KB lights again then suddenly I am sitting at the Windows 10 Login Screen. Its almost like its skipping post is the best way I can describe it. I can choose to restart and then the VGA LED goes out.
Any help appreciated. It may not be anything but it will sit in my mind that if that light is on, something is not initializing correctly and I do not want to boot twice each time I use my system.
