[SOLVED] Gigabyte B450 Aorus Elite compatible with Q-Flash Plus?
Oct 6, 2019
6
Hello, my friend told me that the B450 Elite is compatible with Q-Flash Plus, allowing me to flash the newest BIOS without a CPU installed, but is it true?
I ordered a Ryzen 5 3600 in order to upgrade my build, but a X570 board is not in my budget, and i would be looking for a 3rd Gen Compatible board.
If the board doesnt support Q-Flash, Is there any cheap alternative to a 3rd Gen Board, or what would be the cheapest CPU to pick up in order to flash my bios?
Thanks alot.
You can do the bootkit route, or you can pick up a motherboard with MSI BIOS flashback, which is MSI's equivalent to Q-Flash Plus.
Here is a MSI B450 Gaming Plus which supports BIOS Flashback https://pcpartpicker.com/product/3YhKHx/msi-b450-gaming-plus-atx-am4-motherboard-b450-gaming-plus
Alternatively, here is an MSI B450 that will support Ryzen 3000 out of the box. Its not a very good motherboard otherwise tho.
https://www.newegg.com/msi-b450m-pr...&ranSiteID=8BacdVP0GFs-K8Tlb0y08AGKLRCWcVV.vA
Reactions: kiyu
