Question Gigabyte b450 aorus elite vga light?!!
Apr 26, 2019
Hi Everyone, This is my system
I have recently built a new system, M/b b450 aorus elite, Ryzen 2600X watercooled, rx 580 8 gb, My problem is i have a vga light's on and every thing else is working fine!! and i don't know where is the problem from and really i need your help because i am afraid that it will harm my PC in anyway possible.
Any advice or tips will be appreciated, Cheers.
thanks Scout for you reply, i didn't do a cmos reset but i am using it heavily in gaming and stuff and everything seems fine to me, no over heating playing on the highest setting always but this light really annoys me!!
Update, so i did a reset to the bios and i plugged the Dvi cable instead of the HDMI from the Rx580 and the vga light turned off!! , After a while i plugged the HDMI then the lights came back.I am guessing that it is related to bios is unable to detect a graphics card through the HDMI port and if it doesn't affect me in anyway i'll continue using it normally. If someone has another opinion i would be pleased to hear it.
Thanks for your help, Cheers.
