Review Gigabyte B550M Aorus Pro Review: Reasonably Priced, Capable MicroATX
Not sure why the author beats on the "no integrated wi-fi" drum. Desktop systems are largely stationary, and many certainly use ethernet for the network connection rather than wi-fi, as they should. Having the option to purchase a board without a wi-fi chipset, which would be a useless component (and therefore expense), is appreciated. For those do want wi-fi, they can use an add-in card (as noted) or find one of the multitude of boards that does have wi-fi.
Also, having a smaller number of SATA and M.2 slots is par for the course for mATX and mITX boards, isn't it? Not sure that's really a legitimate knock against the board either.
Should also note that there is an updated version of this board, denoted with a -P, that upgrades the ethernet to 2.5Gb and ups the supported RAM speed to DDR4-4400. The audio solution may or may not be different (different model numbers are shown in the Newegg listings). Otherwise it seems identical.
Reactions: JamesSneed
This was a very lazy review. All of the cons really are not cons for 99% of the people building a mATX build.
Why would you want more than 4 SATA ports? 4 is too many already, 2 would be perfectly fine. SATA is legacy anyway, and most people should have their harddrives in a server, not in their desktop. No WiFI? That's a plus. And who needs so many USB ports?
The real minus is lack of 2.5GBps Ethernet - that's rules it out for me.
There's a new one with 2.5GBs B550M AORUS PRO-P
Well, with the amount of cores that these higher end builds may have, setting up a small VM for a server is a piece of cake. Why have the expense of a completely separate machine when you can take the one you have, allocate 2 out of 16 cores to it, some ram, and then just add 3 or 4 large HDDs for your server.
Personally, 4 SATA ports is just about perfect. 1 NVME M.2 port for the boot drive, 1 SATA for large storage for the main machine and 3 SATA for the VM server. Or, just put all 4 SATAs to the VM and map the large storage for the main system to the server. It would almost be as fast as local storage.
And yes, I do agree with the 2.5G ethernet. These days many people are looking for more than your typical 1Gb networking. Still, the board looks pretty solid otherwise.
The MicroATX B550M Aorus Pro performed well in our tests and even managed to overclock the Ryzen 9 5950X. The $129.99 board is a step up from the DS3H, including more robust power delivery, improved audio, a heatsink for an M.2 module, and more.
Gigabyte B550M Aorus Pro Review: Reasonably Priced, Capable MicroATX : Read more
why no comments about the b550 usb bug that is particularly bad with gigabyte b550 boards? Having your USB port drop out randomly is somewhat of a major con. Did gigabyte manage to fix that for this board? Last I looked yesterday they were still waiting for a fix from amd (for a similar board).
You are right, but integrated wifi comes with integrated bluetooth, Wich is needed for VR.
Since VR already uses a lot of USB ports, and this motherboard has limited PCIe extentions, that make sense to mention it, but not the way it was in the article.
