CPU: AMD Ryzen 5 7600X 6-Core Processor6 Cores
GPU: AMD Radeon RX 7900 GRE
PSU: MSI MAG A650GL 650W 80 Plus Gold
Motherboard: Gigabyte Eagle B650 AX
RAM: KINGSTON Fury Beast 32GB 5200MHz
SSD 1: KINGSTON KC3000 1TB
I noticed that around the windows update time (I'm on win11) my CPU LED on the motherboard lit up and stays lit up, even when the PC is booted up.
Also boot up time is now few times longer, it starts to boot up normally with the GIGABYTE logo and the loading circle (which moves), and then the dispaly flickers and it gets stuck for around 30 seconds on a black screen with just the loading circle (the circle now doesn't move at all) and then it changes to the windows welcome screen which loads a bit longer than usual as well.
In device manager the iGPU has an exclamation mark(error code 43). I unistalled the drivers with AMD cleaning utility (and then installed them again)which booted windows up in the safe mode, and the boot time was normal, but the CPU LED was on nevertheless.
I turned the iGPU off in BIOS and there is still a problem with the CPU LED on the motherboard, same for the boot time. I cleaned (just blew some air on it with my mouth) the CPU power socket and unplugged and plugged the CPU power cable in again. I unistalled the windows updates, and it didn't do anything, but in update history the updates still show as installed.
I updated BIOS using Gigabyte control center app from version F1 to F34, I took out the CMOS battery for about 6 minutes and it still the same issue.
I build this PC a little over a year ago. I used to have a RAM issue it wasn't stable when using XMP, crashing games after half an hour or so, so the XMP is turned off (I checked and it's definitely turned off even after updating and resetting BIOS).
CPU temps are normal, around 40C on idle, and up to 80 on 100% utl - but I'm not using too much in terms of cooling.
The PC seems to be running fine, I'm not using it heavily, so can't really tell, but an hour long gaming session is regular and there's no crashes or anything.
Thanks for helping and let me know if there is some information missing.
