Gigabyte front panel connectors
I wasn't able to find a good enough picture online to confirm this on your board, but on every mobo I've seen, the connectors are labeled, but with very small print. You should see PWR SW, PWR LED, HDD LED, etc, with little + and - symbols to indicate positive and ground pins.
Thanks for the reply.
My motherboard (GA-Q87TN) did not have the pinout in the manual or on the board. But I found another one (GA-Q87N) which did have the pinout. The colors and the polarity (specified by the plus signs) matched. So I used the pinout from the other manual and everything seems to be working for now.
EDIT: The board did have plus signs and colors but no labels.
