gigabyte g1 sniper z87 problem
Slovenia rulez
154
System specs:
intel i5 4690k
asus gtx 970
3tb seagate baracuda
256gb samsung 840 evo
Chieftec cft650w power supply
Nzxt phantom big tower case
I just got a brand new motherboard and i really cant play any game with my speakers through the motherboard audio,there is really annoying buzz in the speakers,especially when loading games.
Only 1 game hasnt got the buzz,the game need for speed rival! (That has a 30 fps lock).
I really dont want to invest in a discrete sound card,since this one has excellent qualoty audio...
Any suggestions?
Speakers work fine on any other pc and i already tried changing aux cable...
This happens only in games!
Should i just buy an asus xonar dgx sound card and let that do the work,but it will definitely not sound that good...
Okay i had an issue kind of the same with this board before, I would get this odd out of sync crack or phase sound. Is there anyway of recording the sound so i could listen to this. I use my computer for making music and this could be too things
1 It could be a ground loop, This would be limted to if you have a ground loop in the wires,
2 it could be that your bios is acting up with the Soundcre 3D soundchip, I've had this happen when updating the creative sound drivers and i fixed it by updating the bios.
Would help with a small sample of the sound could tell what this is right away.
Ok,this happens when i start far cry4 for example :
It is heard only from speakers,no coil whine from the graphics card...
Here is the link to the audio file:
http://
