GIGABYTE G1 Sniper Z87 - sound problem
masterzoya
Hello everyone, yesterday my Windows was broken so I decided to reinstall it. I did it but I couldn't have saved my Sound Blaster equalizer settings. Now I can't make possible to listen anything. Also before when I had REALTEK my equalizer was on ROCK but now on Sound Blaster it's not the same sound when I put it on ROCK. I tried to count 31/62/125 etc. and to make it custom on Sound Blaster with same numbers which I had in REALTEK but nothing... still not the same.
Can I install Realtek HD Audio Manager, I have GIGABYTE G1 Sniper Z87 which has Onboard Creative Sound Core3D™ quad-core audio processor? If I can't install it, can anyone share his Sound Blaster equalizer so I could maybe fit into it.
I don't understand... Do you have a sound card, or are you using the on-board sound?
If you are using the on-board, have you installed the creative audio driver, such as shown here:
http://www.gigabyte.us/products/product-page.aspx?pid=4802&dl=1&RWD=0#driver
Don't actually install the one from that list - you need to make sure you get the one for your version of windows.
If you install the motherboard driver, you should have an equalizer/control that works for your system.
