Gigabyte G41 M Combo Problem Cpu Fan spin then stop then spin then stop I always have to switch off psu then start PC again I recently change psu all thing only mobo not changed
When posting a thread of troubleshooting nature, it's customary to include your full system's specs inclusive of your OS. Please list them as:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
You've also stated that you changed the PSU, mind sharing both the old and the new models. On that note, why did you need to swap out the PSU?
I'm assuming the case is also generic? Your system doesn't have a discrete GPU? Have you made sure all the connections from your PSU to your board are made? Are you sure that the front panels wiring are in order?
