Gigabyte GA-875M-D3H too many usbs problem
Sep 18, 2018
Hello there
i have following problem with my computer
My system works fine as long as i have up to 4 usb peripethals connected
1 mouse 2 keyboard 3 sound card 4 wifi dongle
Once i try to connect anything else via usb some devices start malfunctioning
namely either mouse lags every couple of seconds or wifi dongle (tried 2 different tp link ones) loses connection or even becomes disabled. Fifth peripethals usually malfunction as well.
Problems persist till i remove fifth peripethal and restart computer.
Now i only use usb ports at the back of the pc case, tried multiple configurations of them.
My specs are
Gigabyte Radeon RX 580 (problem occured with older card as well)
Intel Core i5-3350P 3,10 GHz (BX80637I53350P)
Crucial 2x4GB Ballistix sport 1333MHz DDR3
Seagate 1TB, SATAIII, 7200RPM, 64MB cache (ST1000DM003) OEM
Windows 10 - i've reinstalled system few times and problem was present all the time, however i don't remember if it always was win10 and not win7
EDIT: Forgot to add problem persists even after upgrading to the newest available bios
Here's a thought. Perhaps one of the USB devices is drawing more than it should.
Perhaps it's not that there are two many USB devices....perhaps there is just one problem USB device.
