gigabyte ga-ab350n-gaming wifi & Ryzen 7 Problem
May 12, 2018
Hi Everyone,
I bought a new pc and parts are listed below;
- Gigabyte GA-AB350N-Gaming AMD B350 3200MHz(O.C) DDR4 Soket AM4 mITX Wi-Fi
- MD Ryzen 7 2700X 4.35GHz 20MB Cache Soket AM4
- Corsair Vengeance LPX 16GB(2x8GB) 3200MHz DDR4 Ram CMK16GX4M2B3200C16R
I setup all of them together and pc didn't post or boot. I googled and found that if I want to use Ryzen 7 2700x with ga-ab350n-gaming wifi bios must be at least F10. Then I got my friend's cpu (Amd A6-9500 3.8 GHz AM4) and mainboard post and booted. I entered the bios and updated it F2 to F22d. Changed to my Ryzen 7 2700x cpu but mainboard didn't booted again. only blank screen showed up. I tried to remove one ram or cleared the C_MOS but nothing changed.
Please someone help me to get trogh this.
Thanks
U said that u flashed ur bios !! so I would like to know is the pc bootable with the AMd A6-9500 still after the bios update !! just to verify u didnt messed up ur motherboard and plus if it does does it show an boot up screen ii mean the motherboard logo ?? and if it does click del and go to bios to see if it recognising ur ryzen cpu !
UPdate me up when u do the above things !
After bios update motherboard still boots (shows gigabyte logo) with Amd A6-9500 3.8 GHz AM4 but when changed to ryzen 7 2700x cpu nothing shows up even no gigabyte logo, just black screen.I tried to pressed del to enter bios when screen was blank.
i Mean its hrad to say but i think the problem is with ur ryzen !! u should get it checked by the service centre or file a replacement for it or get it RMA asap !!
I am having the exact issue as you with this exact same MoBo. I have 2600X and it wont POST 90% of the time I just get a blank screen, but when install my Ryzen 2200G everything works fine.
I was on F22 BIOS and even tried F23D the latest but still having the same issue.
Please let me know if you found a solution.
