Gigabyte GA-B75M-D3H 12 v power connector problem
Darian Vs
26
hi
i bought a gigabyte GA-B75M-D3H mobo. i did not no until i opened the package that it was a rev 1.1
http://www.gigabyte.in/products/product-page.aspx?pid=4315#ov
but the one i browsed while looking for this board was a rev 1.0
http://www.gigabyte.in/products/product-page.aspx?pid=4150#ov
i didnt know that two versions existed until i opened the package. the rev 1.1 has a 8 pin power connector whereas the 1.0 has a 4 pin. my psu is a Corsair VS450
http://www.corsair.com/us/power-supply-units/vs-series-power-supply-units/vs-seriestm-vs450-450-watt-power-supply.html
what should i do pls help
I've left mine open before...never had a problem....
But I would recommend to save for a proper supply for future...
Your supply will be older as it only has the 4 pins.. so I don't know how long that will last anyways!
I follow a rule that my engine needs an oil change every 5 months (synthetic) so my power supply in my pc needs a replacement every 5 years.
JQ
Jynx. Owe me a coke. :bounce:
then there is no prob in leaving the first four pins? i wont be overclocking as b75 chipset dosen't support it. for normal usage its ok right? should i cover the first four pins or leave them open?
JQ
