[Question - 799576
Sent : 8/22/2009 16:34
Question : I am building this system and when I start it up after it's been running for only 2 seconds, like a restart, I get a long 5 second or so alarm and the video card won't start. if I wait for a few minutes it will start. So the alarm will come on at start up when it's cold, and when it's hot, or it won't come on and it will start. HELP!
Model Name : GA-EX58-UD3R(rev. 1.0)
M/B Rev : 1.0
BIOS Ver : F2
Serial No. : 090200006170
Purchase Dealer : pixmania
VGA Brand : ATi Model : 4870HD
CPU Brand : Intel Model : core i7 920 Speed : 2.66
Operation System : SP :
Memory Brand : Corsair Type : ddr3
Memory Size : 6GB Speed : 1066
Power Supply : 650 W
Answer - 799576
Answer : Dear Christopher,
Thank you for your kindly mail and inquiry. About the issue you mentioned, because several possibilities might cause the problems, such as something wrong with memory, motherboard, BIOS, power, attached hardwares...etc. We suggest that you could try to do a simple test first:
Remove such as add-on cards, devices from motherboard, only install CPU, single memory, VGA card and power (simple environment), and make sure the components on the motherboard are installed properly, then please take off the on-board battery to leak voltage to clear CMOS data by following the steps below:
1) Turn off power.
2) Remove the power cord from the PSU.
3) Take out the battery gently and put it aside for about 5 minutes or longer. (Or you can use a metal object to connect the two pins in the battery holder to make them short-circuited.)
4) Re-insert the battery to the battery holder.
5) Connect power cord to PSU again and turn on power.
6) Power on your system.
7) If BIOS can POST, please enter the BIOS and load the fail-safe defaults setting.
7) Save changes and reboot the system.
After clearing CMOS and load the fail-safe defaults, please test your system in a simple environment to observe the result. If there's nothing wrong in simple environment, try to install several additional cards into the slot one by one to observe the result again and again.
But, if the problem still occurs in a simple environment, then a further testing or examination to your system might be required. We suggest you can contact your supplier or nearest distributor and see if they can help you to test your system directly. For distributor contact information, please click HERE.
We are really sorry for the inconvenience you have with our product.
At last, if you still have any further question or suggestion about our products/service, please do not hesitate to contact with us. We will try our best to help you resolve the problem ASAP.
Regards,
GIGABYTE TECHNOLOGY
Question - 800211
Sent : 8/24/2009 16:53
Question : Thanks, I'll try the simple environment. Is it possible that the bios needs to be updated?
Question - 800390
Sent : 8/24/2009 23:47
Question : Please refer to email ID 800211
I took out the cmos battery as you instructed and removed items to get to a simple environment. I then loaded fail safe defaults and it was fixed, temporarily. I added back items one at a time and everything was working fine until it started crashing with the blue screen of death. When I restart I get windows error mode screen but it's frozen and it's impossible to scroll I just have to wait for 30 seconds and it tries to restart. the last crash was when installing kaspersky antivirus and now it won't boot because it says that klbg.sys is missing but it won't boot from the cd rom drive even though I put it first in the boot sequence (with vista installation disc in the cd rom). Now the original problem of the beep upon start up is back which tells me it's not a hardware issue. There is some serious incompatibility going on. I also went into the Qflash function to see what was up with that (I didn't try to flash the board)and the Qflash page is just as frozen as the windows error reporting page. I contacted the vendor who wrote back and told me to send it back to them and then wait for A MONTH OR TWO for the board to be tested and maybe it would be replaced. THIS IS NOT ACCEPTABLE!
M/B Rev : 1.0
BIOS Ver : f2
VGA Brand : ATi Model : hd4870
CPU Brand : Intel Model : i7 920 Speed : 2.66
Operation System : Vista 64-bit SP :
Memory Brand : Corsair Type : DDR
Memory Size : 6gb Speed : 1066
ddr3 ram 3x2 gb
Answer - 800390
Thank you for your kindly mail and inquiry. According to your description, there may be a hardware compatibility problem with your motherboard, and because our warranty service is provided by the original supplier and the distributor in that area, so we also suggest you can contact the distributor in your area and see if they can help you to test the system directly. For distributor contact information, please click HERE.
Regards,
GIGABYTE TECHNOLOGY
Question - 800716
Sent : 8/25/2009 18:13
Question : I have contacted the seller, Pixmania, here in Portugal. They are not helpful. Even according to their own policies, they should replace the board as I contacted them immediately. Unless Gigabyte pressures them to swap the board they will not. Can you please help with this?
Answer - 800716
Thank you again for your kindly mail and further information. As we mentioned in the previous mail, our warranty service is provided by the original supplier and the distributor in that area, so if your original supplier refuse to help you, then we suggest you can also contact the distributor in that area for furthering help. For distributor contact information, please click HERE, sorry for the inconvenience.
Regards,
GIGABYTE TECHNOLOGY
Question - 801175
Sent : 8/26/2009 17:36
Question : Dear Gigabyte,
I contacted all 3 distributors listed on your website: inclass.pt, introduxi.pt and niposom.pt. They all told me they will not help and to go to the seller for resolution and as I have already written to you, the seller will only forward the board on to you for repairs. This is not customer service and Gigabyte does not even provide a live resolution or technical support service. Gigabyte and the seller have a responsibility to provide assistance, not just send me in circles that lead nowhere. I purchased what is supposed to be one of the best boards around, and the most reliable. Reliability is very important. The reason I chose your board is that it's advertised to be "ultra durable". Since I have been struggling with this issue I have performed extensive research on the web and my configuration of components is not at all uncommon. Yet the only comments I have seen with this configuration have to do with the possible need to update the bios because of the issues I have described to you, or people who had defective boards that were replaced by yoiu and then everything was OK. Are you going to stand behind your product and your reputation or leave me stranded???
Answer - 801175
Thank you again for your kindly mail and further information. Please update your motherboard BIOS to the latest version and test again.
To download the latest BIOS, please click HERE.
And for BIOS update instructions, please click HERE. Please do not forget to load BIOS fail-safe default setting and please also do not try to overclock your system at this moment.
Regards,
GIGABYTE TECHNOLOGY
Question - 801671
Sent : 8/27/2009 17:33
Question : Hi again,
The Q flash (end button) command on startup brings me to the update screen which is frozen - inoperable. When I hit delete on start up and use F8 in the bios it brings me to the flash utility which won't recognize the (FAT) pen drive with the F6 bios update on it. (The F6 update is what is recommended by your US automatic driver detect site.) Still hitting a wall here and going in circles.
Answer - 801671
Thank you again for your kindly mail. If possible, we suggest you can test the system with different USB flash driver to see if there's a single device problem.
But, if the problem still occurs, we suggest you can contact your supplier or nearest distributor and see if they can help you to check your system directly to see if there's a hardware or BIOS problem, sorry for the inconvenience.
Regards,
GIGABYTE TECHNOLOGY
Question - 802175
Sent : 8/28/2009 19:33
Question : Thanks for the reply. Just exactly how would both the q-flash screens being frozen be a usb device problem? The screens are frozen whether or not a usb drive is connected. Those screens are coming from the bios. As I have already explained, the distributor and the seller are not interested in providing support, and you won't answer even the most basic questions like which version of the bios update should I be trying to flash the bios with IF I COULD GET THE FLASH FUNCTION TO WORK AT ALL!!!!!!!
Answer - 802175
Thank you again for your kindly mail. We suggest you can go to "Integrated Peripherals" submenu in the BIOS, enabled the "USB Keyboard Function" then try again, and if possible, we also suggest you can test your system with different keyboard to see if there's a keyboard problem.
Regards,
GIGABYTE TECHNOLOGY
Question - 803197
Sent : 8/31/2009 18:32
I have done what you suggest, the USB Keyboard Function was already enabled. I have another weird thing going on as well and that is that the Gigabyte intel 5-series utility dvd will not load. when I started up the computer originally I loaded the drivers (according to Gigabyte's manual), but I wanted to double check things and I wanted to install easy tune and G.O.M. but the cd/dvd window comes up and it says "loading" but it never loads. It just sits there trying to load forever. All other cd/dvd's work fine and this Gigabyte intel 5-series utility dvd will open so I can read the directory in any other computer I have. So in summation: I still have multiple problems going on that appear to originate in the BIOS, which has now been updated, and I am not getting helpful answers. I'm sure I'm not the only one who is having issues with this mobo and it sounds like you don't have answers nor will you exchange the mobo to see if that fixes it. This situation is typical when there are design problems for which the manufacturer does not have solutions. So instead you just humor your clients and send them in endless useless circles while never actually providing effective support.
Answer - 803197
Thank you again for your kindly mail and further information. For product replacement issue, different local resellers or distributors may have their own replacement policy. Please contact your supplier for more details about the warranty for your product. For distributor contact information, please click HERE, sorry for the inconvenience.
Regards,
GIGABYTE TECHNOLOGY
Question - 803643
Sent : 9/1/2009 18:39
Question : Thank you Gigabyte.........thanks for nothing.........I will now take my issues to the public domain, I assure you I will spend no small amount of time and energy to make sure that everyone on the net knows how you do business, for the next few years....I have a lot of time on my hands....
Answer - 803643
Thank you again for your kindly mail. We are deeply sorry for the inconvenience you have with our product. If you still have any further question or suggestion about our products/service in the future, please inform us again.
Regards,
GIGABYTE TECHNOLOGY
