Gigabyte GA-H97M-D3H with four system fan
davide445
133
Want to buy this mobo for my new rig.
Will be inside an Aerocool DS case, coming with 1x200mm front and 1x120mm rear pre-installed fan, I want to better cool it down using 2 more fan on the top.
Gybabyte specs state support for 3 x system fan headers, so can I in some way power four fan?
I would power them straight from your power supply. Depending on what power supply you have, most have a few 3 or 4 pin connectors and I think all power supplies have molex connectors. And you can buy adapters that go from molex to 3 and 4 pin.
Will buy this one http://
Very good choice of power supply. And it has molex connectors, so you can get a molex to 3 pin or 4 pin, depending on what type the fan has. Some fans use a molex connection instead of a a 3 or 4 pin.
Here is a picture of a molex to 3 pin connection. The molex is on the left and the 3 pin is on the right.
https://www.google.com/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&uact=8&docid=9WGDCFZata6UnM&tbnid=uLwVPBePt9AM3M:&ved=0CAUQjRw&url=http%3A%2F%2Fforums.ncix.com%2Fforums%2Ftopic.php%3Fid%3D2164063&ei=xGv6U_fcBrSK8gGJqYGgCA&bvm=bv.73612305,d.b2U&psig=AFQjCNHHdAu4T2pnLqDR62Zp__Y8x68cfg&ust=1409006915121192
Will need to power
2x Noctua NF-A14 PWM
1x Aerocool Silent Master 200mm
1x Aerocool DS Dead Silence 120mm
Need I a molex?
You have 3 system fan connectors on your motherboard, and then at least another 3 molex connectors on the PSU. So you should be just fine.
