Question Gigabyte GA-P31-DS3L wont read bootable w10 usb
MrGreener
Commendable
Apr 20, 2020
12
Gigabyte GA-P31-DS3L wont read bootable w10 usb no matter what things i enable / disable in bios and its getting annoying
I followed some youtube tutorials that said how but they dont work, are they fake, can it even work ?
You have to make the install media on a legacy BIOS machine. If you make it on a UEFI machine, the USB ends up with a GPT formatted partition which your BIOS can't read. Remember the BIOS is before any drivers, so even if your machine can read the stick fine in Windows, that doesn't help you to boot from it.
And the USB stick should be 16GB or 32GB as quite a number of old machines can't seem to boot from 64GB or larger.
Already did that, downloaded the w10 tool and made the bootable usb on the Gigabyte GA-P31-DS3L PC, doesnt work.
USB is 16gb.
