Gigabyte GC-WB867D-I Wireless/Bluetooth 4.2 Card Problem
t.f.trayton
4
Hi,
This question may have been asked before but anyway, here goes. I need to know whether anyone can advise where I can obtain an adapter which will allow me to connect the USB 9 pin cable from the GC-WB867D-I card to an F-USB header on a MI 7778 Ver 1 motherboard. There are two of these headers available but the pins do not match up to the connector as there are two 'blanks' on the header coinciding with the 9th pin position of the cable.
I hope someone can follow this as it seems there is little else I can do to explain the situation other than to say that the header on my MB doesn't match up to the cable from the Gigabyte card.
Pictures help in these sort of circumstances.
Align the USB connector from the Wireless card to the left most pin on the USB prt connectors on the motherboard, with the 4 wires coming off the top of the connector like so:
index.php
Following my earlier reply I should have asked, as I am a newcomer to this forum I am not familiar with the attachments procedure otherwise I would have provided some pictures.
