GIGABYTE GEFORCE GTX 1050 TI OC vs ZOTAC GEFORCE GTX 1050 Ti OC 4GB
shafin12345
48
Hello,
Today my old Gigabyte GT730 died, and Im in an urgent need to buy a gpu within a few days, Only the GTX1050TIs fit my liking, Ive come down to Gigabyte gtx1050ti oc and Zotac gtx1050ti oc as my last options.
Gigabyte one costs $172 in my region and Zotac one costs $190 in my region
Im not looking for solid 60 fps with ultra settings, 50+ fps with med/high settings on all games is more than enough for me, also 900p resolutions are more than enough for me.My case is actually pretty small so I dont think it can handle anything more lenghty than 200mm (my current gt730 takes like 75% space which lenghts like 160mm). Also the fact that my psu dont have 6 pin connectors and only these 2 are without 6 pin connectors.
And my general specs :
Windows 8 64 bit
Intel core i3 4160
4x2 8gb ddr3 ram
350 watt psu
Also Id like to mention that my town is kinda extra dusty so dust is a HUGE problem
With these in consideration I hope some of you can help me pick 1 as soon as possible 😀 Thanks and cheers.
Go with Zotac 174mm x 111.15mm cause its smallest card of your picks and it will fit surley.It doesn't matter if you pick with 6pin or without it. It will run same.
