Question Gigabyte GeForce RTX 3060 Ti Vision OC 8GB vs Gigabyte GeForce RTX 3060 Ti Gaming OC 8GB ?
4
Hello, i wanna know is there any problem with my PSU?
The GIGABYTE GeForce RTX 3060 Ti VISION OC 8GB recommended psu is 650W my 600w psu gonna enought? Its a rev2.0 card. idk what is that mean.
The GIGABYTE GeForce RTX 3060 Ti GAMING OC 8GB recommended psu is 600w i know this gonna a good pair with my psu. Its a rev 1.0.
Whats the different on rev 1.0 or 2.0?
The 2 cards is the same price.
My PSU is:
Cooler Master Elite V4 600W (MPE-6001-ACABN)​
And here is my other components:​
SDD: ADATA LEGEND 800 1TB M.2 SSD (ALEG-800-1000GCS)​
Motherboard: ASRock B550 Phantom Gaming 4 alaplap (90-MXBCY0-A0UAYZ)​
RAM: Kingston FURY Beast DIMM 2x8GB 3200MHz DDR4 memória (KF432C16BBK2/16)​
CPU: AMD Ryzen 5 5600G processzor (100-100000252BOX)
Help, i dont know what im gonna do.​
My PSU is:
This is a POOR quality budget PSU model. Definitely NOT recommended to be used for the RTX 3060 Ti. CM Elite PSUs are not known for their build quality.
Please get a high quality power supply. Regardless, of whether the cards require either a 600 Watts or 650 Watts PSU, your current model is low quality, entry-level TIER model.
Bottom of the barrel. PSU's Wattage number alone means nothing. The make and build QUALITY of the PSU matters the most (OEM, components used etc.)!
https://www.coolermaster.com/catalog/power-supplies/elite-series/elite-v4-230v-600w/#specifications
Don't worry about the revision numbers. These don't matter for end consumers. Those are just different SKUs made by the company, with some minor additions and changes.
The GPU specs still remain the same.
Thx, for the info.
What psu do u recommend me?
There are many good models. It all depends on your current budget.
