Gigabyte gerforce gtx 660 ti OC guru II help
LexGaming76
17
So I just downloaded the OC guru II for the Geforce gtx 660 ti from Gigabyte's website-http://www.gigabyte.com/support-downloads/utility.aspx?cg=3, and when I click on the OC guru II tab it says "Please confirm whether to support this VGA card!'' and when I click OK, it doesn't do anything..... my Monitor is running good, my Video card is running good, and I'm running on HDMI. Any Ideas or Concerns? Thanks!
My best recommendation would be to use a different overclocking software. OC guru is known to be kinda bad.
MSI afterburner is simply
EVGA's overclocking software is god
Asus gpu tweak is good too
I have just fixed this issues for myself
It is caused when you upgrade your graphics card without removing the old driver. To remove old driver run cmd prompt as administrator
Paste in the Line
SET DEVMGR_SHOW_NONPRESENT_DEVICES=1 press enter
the open device manager by typing devmgmt.msc
click view and show hidden devices
Locate your old cards under display adapters then uninstall don't forget to tick the box that says remove driver
this sometimes has the effect of removing your new driver as well but just scan for hardware changes and this will go back on for you. restart if it prompts.
hope this helps
