G
Guest
Guest
I've been trying to find which part is the culprit that makes my new built pc keep reebooting while playing games.
here is my Built:
CPU: i7-930 @2.8 ghz
Mobo: Gigabyte x58-ud3r
Graphic card: Gigabyte gtx 470
Memory: Corsair XMS3 in triple channel, 6gb, 1600 mhz
CPU cooling: Xigmatek HDT-1283s
PSU: HEC Zephir 750 watt
HDD: 2x500gb WD AAKS in Raid 0, OCZ vertex 2 60gb for OS.
Problem:
Keep rebooting while playing game.
Suspect:
Faulty Mobo, RAM, CPU, Graphic Card, PSU
Tested:
The corsair memory is good, after 2 hours memtest 86+, no errors, working at rated speed @1600 mhz, 9-9-9-24
Prime95- max temperature: 61C after 2 hours testing, no errors, no crashing
MSI Kombustor with 75% Fan (afterburner): PC reboot after 10 mins, after reboot, immediate test carried, the system reboot immediately.
Now which part is at fault? Graphic card? or PSU? or Mobo?
This PSU is an old psu, The PSU was used with my old built: 2x9800Gtx+ in SLI, Overclocked Q6600 at 3.5ghz, 750sli ftw, everything is stable.
The Mobo's SB heat up around 65C (using HW monitor), some fingerburn when touching the pipe
The GPU heat up around 67 before pc reebot (using MSI combustor)
I played L4d2, for good 30 minutes (Until 3rd stage of the Parish), then Pc reboot without warning, without BSOD, no error messages.
Which part do you guys think should I RMA?
here is my Built:
Problem:
Suspect:
Tested:
