Hi Guys,
I'm trying for a long time to identify why I have some weird fluctuations in FPS for games... and recently I narrowed it down to my GPU/PSU.
Using EVGA Precision X I've left the stock settings and I've noticed that in games the power % stays at max 70%. This happens even if I OC the core with 90 Mhz and memory with 180 while setting the power taget to 112%.
I've looked for examples on the net, and noticed other cards reach at least the 100% intended power level.
Should I be worried that my PSU is not giving enough power to the card? I've heard some noises with it before, but I really couldn't track the issue to it.
Thanks in advance for your help.
As i understood 8 pin needed to ensure card can get 150W from PSU for sure, as 6PIN delivers 75W by standard, and +75W from PCIe slot. It is like safety factor from manufacturers, as they sure that if You have 8 PIN your PSU can provide 150W for sure, some info got from here http://www.tomshardware.co.uk/forum/355547-28-adapter-question. And lot's explained about PINs here http://forums.anandtech.com/showthread.php?t=2066334.
