Question Gigabyte H170N-WiFi (rev-1.0) Motherboard CMOS battery CR2032 Replacement.
Oct 1, 2023
5
I would like to replace CMOS battery CR2032 but the manual of GA-H170N-WiFi motherboard did not mention about the details of JST connector to which the battery is attached through a pair of wires.
What is 2-Pin JST specs? Is it JST-GH (1.25mm pitch)?
Lutfij
Could be a JST-PH2.
Take a look at this and see if the connectors match up;
with that on your motherboard. You'll need sliding calipers to measure the width
Oct 1, 2023
5
It is JST SH/SR (1.0mm pitch). Please refer the following product ad.
FYI, I measured from center of hole to the center of next hole of JST connector (female) using a foot scale and confirmed that the spacing is 1 mm only.
I appreciate your help and thanks.
