Hi,
I own a Gigabyte GA-78LMY-USB3 mobo which is my platform for an AMD Bulldozer FX-4100 CPU which is socket AM3+. I've looked at various motherboards which supports this CPU and most of them uses only a 4-pin CPU power connector for said CPU. Because the Gigabyte mobo also supports the new Hexa Core X6 AMD CPU it comes with a 8-pin CPU power connector.
Question is,:
Will I damage the AMD Bulldozer FX-4100 processor if I use the whole 8-pin connector? So far I've managed to figured out the 8-pin power connector is actually 2 x 4-pin connectors, and that the CPU draws about 95watts. I have been fine with using only one 4pin CPU power connecter.
But looking at CPU-Z it throttles between 1206 MHz with a Multiplier of x 7.0 and 4.2 MHz (not sure on the multiplier, its overclocked) I do overclock from 3.6 MHz Stock; and 4.2 MHz OC Core speed.
Question is,:
