Gigabyte MOBO Help!
Yes the live update will, there is also a bios update component
The GIGABYTE APP Center gives you easy access to a wealth of GIGABYTE apps that help you get the most from your GIGABYTE motherboard. Using a simple, unified user interface, GIGABYTE APP Center allows you to easily launch all GIGABYTE apps installed on your system, check related updates online, and download the latest apps, drivers, and BIOS.
(Note) Please install Microsoft .NET Framework 4.5 first before install APP Center utility.
