Gigabyte motherboard help!
Megamatt
5
Hi all, i have just been putting together a parts list for a pc I'm planning to build and I went to order the parts but i can't find the motherboard i plan to use anywhere. I have tried over 20 websites but cant find it anywhere even though there are hundreds of reviews for it on you tube and it has a page on the gigabyte website. The motherboard is a Gigabyte GA Z77X UDH5 WD WiFi. Any help or links to a website i could get it from would be greatly appreciated.
Thanks all, Matthew
I found one here but I never use and hear this site. http://www.tamayatech.com/parts.php?g=GAZ77XUD5HWB or you can get the used one from amazon http://www.amazon.com/gp/offer-listing/B007R21JJA/ref=dp_olp_used_mbc?ie=UTF8&condition=used
But if you just want to build the new PC, I recommend to buy the 4th gen intel i5/i7 k version and the Z97 MB, if you want the MB with wifi http://pcpartpicker.com/parts/motherboard/#c=99&e=31,15,30,14,6,8&sort=a8&f=2 Also you can always add the wifi yourself.
