Gigabyte motherboard USBs' possible problem
Mohsen_mzh
16
Hi
I have a GA-890GPA-UD3H (rev. 2.0) motherboard which I guess it has some problems with USB slots. Some devices connect slow or not at all sometimes. My wireless network adapter hardly connects to a wifi network and even when it does I have a very bad ping with modem IP address(192.168.1.1) and packet loss is high. Same thing goes for my phone when I try to connect it using USB, it hardly connects. restarting the computer works sometimes and it gets better but not all the times. the devices I mentioned work fine on my laptop.
I have reinstalled all the motherboard drivers, updated bios driver, used other wireless network adapters and nothing changed.
Is there anything I could do before reinstalling windows? which I guess doesn't solve the problem.
Any software out there I can use to make sure USBs work fine?
Thanks in advance.
I downloaded the file you mentioned, seems I already have installed all drivers and they are up to date.
How can I make sure if it's a low voltage problem? and how can I fix it?
Thanks
Thanks for your response
Voltage was fine after all and reinstalling windows didn't help. The problem is not just for wireless adapter, I have almost the same problem with my phone but I just bought an PCIe wireless adapter and I can use it with no problem.
I just don't want to buy another motherboard just yet plus that I'm not sure it helps, but I can't think of any other solutions either.
Thanks again for your help.
Thank you, it worked! I'm using a USB hub with power supply and everything's fine now. wireless adapter and even my phone are connected with no problem.
