[SOLVED] GIGABYTE Radeon RX 5600 XT GAMING 6G vs SAPPHIRE Radeon RX 5600 XT 6G vs GIGABYTE GeForce RTX 2060 OC 6GB?
Jul 2, 2020
19
Hi!
I want to upgrade my GPU, there is 3 option but I dont know which one is the best choice.
Gigabyte RX 5600 XT is the cheapest one, Sapphire and RTX2060 has same price in my country.
Motherboard: ASUS Prime B360M-A
CPU: I5-9400F
RAM: 2x8gb 2666MHz
PSU: Be Quiet Pure Power 11 600W
Thanks for in advance.
I Highly Recommend the Sapphire 5600 XT, I used to be a NVidia/Gigabyte Fan Boy, GTX280, GTX 660TI 3gb GTX 1060 all Gigabyte, the 1060 wore out and had problems so I tried something new this Go round on the two PCs i built (mine and wife's) for her's i got the Sapphire 5600 XT and it rocks the Dual Bios Feature is really nice as stated above, but It's a Quality product for Sure, I'm Trying to Decide between a 2060 Super or 5700xt for my new rig.
Are they all priced the same?
The Gigabyte Gaming and Sapphire Pulse coolers are equivalent. Gigabyte's OC cooler is a lower quality.
Gigabyte Gaming cooler:
Gigabyte OC cooler:
And yes, most manufacturers properly visually represent the coolers on their product pages.
Gigabyte OC cooler:
Thank you mate, it will be Gigabyte 5600XT I think.
