Hello guys today i bought AORUS AX370-GAMING K5 motherboard but i cant find anywhere the rgb fusion to download it and control the leds i saw a video but in my mobo site it only give the option to download the app for phones
Hi, you need to download the RGB Fusion app from the downloads section of your motherboard, be aware that you first need to download APP Centre and then add RGB fusion to this. So download APP Center first and install it, then the RGB Fusion APP. You can also add some other apps to monitor your system...I should mention the APP iCenter s not for the phone it is for the PC then you can download other APPs to install in APP Center like RGB Fusion..
You should also have some basic control from the bios though not 100% sure. I have the Z370 Gaming 7 and it can control RGB from the Bios as well as the APP Center. Hope this helps...
