[SOLVED] gigabyte rtx 2060 temperature and xpg invader case
SOLIDRADENX
18
Hello guys I need u advise in making agood airflow in my case as my card running so hot at loading it reach 84 c so any idea how many fans to add or what to do to reduce card temp as it hot in my area this days I have already two fans installed one is intake and one exhaust
I'd try to get a little more air in there....but I don't think you need much more.
All three of my NVidia cards max out at 82C.....and I've been running like this for years.
You could also try just running with the case open and see what that gets you.
Just be careful not to drop anything in the case.
Mate, that's just not enough when you've got a gaming graphics card in there.
After taking a look at the chassis specs:
Do 2 side intake, and don't even bother with the front
For the top, it depends on the cpu cooler:
-if a tower air cooler, no fans
-if a top-down area cooler, 2 top exhaust
-if a hybrid cooler, top exhaust
Rear exhaust
If for some reason the side is blocked off, unblock it. It provides more effective intake VS the front.
Reactions: SOLIDRADENX
