News Gigabyte RTX 4090 Up Recesses 16-Pin Power Connector
The new model appears to be thinner and narrower, and the 16-pin 12VHPWR power input is pointed toward the tail-end, rather than toward the top of the card.
As compared to original Windforce Model, 13.6 cm vs. 15.0 cm narrower, and thinner as well (5.5 cm vs. 7.0 cm).
So if we judge the new design, it no longer needs to bend nearly 180° as it emerges from the back of your motherboard tray, might help with some cable management (less mechanical strain), no bending up to a roughly 8 cm length, before making a 90° turn to the back of the motherboard tray.
And that's not even going into the, arguably, "less cooling" area. Probably a nothing-burguer, but still funny they're sacrificing that over accommodating the cable XD
Regards.
Regards.
I would argue they went a "bit" overboard on the cooling solutions for the 4090. No reason to OC mine, and at stock it hardly spins up the fans. I would have gladly given up some cooling potential for a 3090 sized cooler I can plop in many ITX cases one day when I repurpose it (3090FE or FTW3 fits lovely in the tiny lian li dan collaboration). A part of me feels like these monstrosities are to help justify the pricetag.
I would dare saying that's more because no games right now actually push the card really hard (CPU bottleneck)... Or the computational type tasks you're throwing at it are not lighting it up?
Cooling is usually meant for something closer to the worst case usage type and the medium abuse IIRC.
In any case, I don't disagree that for some of the 4090 models, the cooling may be overkill; just maybe.
Regards.
You still have to push the connector fully, so user errors still possible.
Agree!
Some takes from the past months:
  1. You get recommended to push it hard until it seats. And then..there has been cases where the entire power connector breaks from the video card.
  2. I wonder if the new connector will be color coded to tell the user when its "plugged correctly".
I can agree. Even at peak gaming mine hovers around 60C.
Totally happy with the card... no issues to report. Didn't like the aesthetics of the anti-sag bracket they included so I improvised.
I can load a random AAA title and hit 60 fps in 4K Ultra and the 4090 is in the 60C range anywhere from 40-60% utilization... meanwhile the 7950x3D is in the 50-70C range showing utilization in the single digits.
That indicates to me the GPU isn't waiting on the CPU and the CPU isn't waiting on the GPU. 🤣
Not necessarily. It'll depend on how the CPU util % is being reported.
If the game engine is not utilizing all the cores, then it means it won't be using 100% of the CPU, but I'm pretty sure 1 or 2 cores will be over 90% and that still classifies as a "CPU bottleneck", except it's an engine limitation more than hardware I guess? You can check that somewhat easily as well.
Regards.
There are a couple big differences to keep in mind, (that are visible) the V2 version does NOT have a vapor chamber as the V1 version had, only a copper plate for GPU/MEM contact (reduced cooling efficiency may result), Interestingly, the fans have also been changed to sleeve fans with "graphene nano lubricant", from double ball bearing fans. It remains to be seen how this will affect performance/lifetime use/fan noise without some form of testing...may or may not matter in the grand scheme of things though.
