Good day!
I have a problem understanding this software menu, The Smart Fan 5 Advanced Tab.
I mainly want to use this so I dont have to download additional software to manage my cooling. I want my computer to be so silent that I can barely hear it when idle, doing easy tasks as browsing, watching videos ect. And I want the fans to rev up when gaming, or stressing the computer with other demanding work. Think I now somehow have managed to get near to this goal.
I have an AIO Liquid cooler for my CPU. Its a Kraken x62, which is run by the software CAM from NZXT. I think this is best suited to take care of all cooling concerning the CPU. As there is many cables going out from the pump and also RGB on the pump. Therefore I think this should not be altered by another software.
There are 3 case fans beside the CPU AIO liquid cooler, and these needs controlling by some sort. I have them all connected to respective fan headers on the motherboard. In SIV Smart Fan 5, under the advanced tab, Im using a curve to set values for fan RPM to set temperatures.
I can select a temperature sensor from the motherboard, for each fan, which it is to take as a reference to controll RPM out from. I can also set fan position for each fan header, making it easier for me to know what fan im altering.
I have these sensors to pick from:
By testing how the sensors react and increase of temperature to stress, I have concluded that the only sensors that really react to stress testing, of CPU, Memory and GPU (Aida 64 Extreme) are the VRM MOS and CPU sensor.
Therefore, if I want my case fans to rev up, when the GPU, CPU and VRM MOS are under stress and their temperatures are increasing, I will need to select eighter the VRM MOS or the CPU sensor.
Selecting any of the other, with 0 to none temperature changes during stress, would only mean that my fans would run as if the computer were idle.
Im now using the VRM MOS sensor for all of the case fans, as that sensor show uniform increases in temperature aswell as reaching the highest temperature increase of all the sensors. The CPU increases by a big jump in temperature, but it also increases by almost the double. Although I think steady increase is better suited for controll of case fans, therefore I picked the VRM MOS sensor over the CPU.
This is how the curve Im using looks, and its the same for all the 3 case fans (System 1, System 2 and System 3 Pump)
Hope you read through it all, as its important to answer some of the questions Im having
1) Is there any good information or guides to this software (SIV) or the Smart Fan 5?
As I could't find any, neighter from manufacter nor any forums or videos.
2) What is the calibration button for, what does it do and why is it needed?
3) There is also Smart Fan 5 settings in the BIOS, what is this for, does it conflict with the Smart Fan 5 in windows, and can it change things you cant with the windows version?
4) Does the Smart Fan 5 software do anything to CPU cooling when I have the pump connected to the CPU header aswell as having the seperate CAM software to control that unit?
5) Im seeing as high as 5000 RPM if choosing the CPU fan in the Smart Fan 5, do this has to do with it adding up both pump and the radiator fans, as Smart Fan 5 can't understand whats connected to the CPU header unlike CAM which is the coolers own software?
6) Is an idle temperature of 30 - 40 C on the Ryzen 1600x CPU OC to 3.9 GHz normal?
7) Is a temperature of 55-65 C on the Ryzen 1600x CPU OC to 3.9 GHz normal/good when stress tested from Aida 64 extreme?
8) What does this table mean:
9) Why are some of the numbers in that table red?
10) Why is that table different than the System 1 fan? As you can see on System 2 fan the red text stop at 60 % where as on both System 1 and System 3 Pump fans, which are the same, the red text stops at 30 %
11) What does the Delta-Temperature-Interval (+-1) do and alter?
This is my rig:
https://pcpartpicker.com/list/tHfKm8
Hoping someone with some knowledge and time in this software can give me some clues, and hoping this can help other new users struggeling with this program.
Thanks a bunch in advance!
This is my rig:
