Gigabyte Windforce 280X way too hot!
PC-Noobist
296
so i bought 2 Gigabyte R9 280X Windforce cards used, they seemed to be in good condition, when i got them they actually had a few problems, so i did my usual with all used cards, pulled the fans off, cleaned and lubed them, cleaned the fin stack, new thermal paste and pads and flashed a newer bios on them, ive gradually done all this and they both while seperate and in crossfire, at 100% fan speed reach 80C and continue climbing until i wont allow them to go any further while gaming, any ideas?
i went and got the newest bios off of gigabytes website, ended up being the same bios, didnt make a difference, i used ATIWinFlash, airflow is great with 2 unrestricted 140mm fans blowing directly through the 2 gpus and 2 140mm exhaust fans ontop of the case, side panel open or closed makes no difference, i honestly cant figure out the damn issue here, i have no OC program install, they are running 100% stock
