Info Gigabyte X870E Aorus Pro - How I Got The Built In WiFi 7 To Work
Dec 9, 2024
23
Had a old HP CD/DVD drive in the case that was used rarely. Tried to use it, just would not work. Since I also have a USB external LG drive that I bought for my laptop could use that. Decided to remove the drive.
Now here is the interesting part...also have a mobile dock installed the I use for off- line storage. The mobile dock is connected to Sata 0 &1 ports. The CD/DVD drive was in Sata 2 port. After booting back up...the WiFi suddenly started working 👍
I figure the chipset shares with the WiFi and Sata port(s) 2 and maybe 3. I have been scouring the net for a solution, and alot of other people are having the same problem. I know it works for my motherboard, maybe others.
CPU: AMD Ryzen 7 9800X3D
CPU cooler: ARCTIC Freezer A35 - Single Tower CPU Cooler
Motherboard: GIGABYTE X870E AORUS PRO [BIOS: F3g]
Ram: CORSAIR Vengeance DDR5 32GB (2x16GB) DDR5 6000MHz AMD Expo
SSD/HDD: Crucial T705 4TB PCIe Gen5 NVMe M.2 SSD
GPU: Asus Dual GeForce RTX 4060 Ti EVO OC Edition 16GB GDDR6
PSU: ASUS TUF Gaming 1000W Gold ATX 3.0 Fully Modular
Chassis: Phanteks Enthoo Pro Series PH-ES614P ATX Full Tower
OS: Windows 11 Home [24H2]
Monitor: MSI MAG 321UPX QD-OLED 32"
Update your post to include full system hardware specs and OS information along with the make and model information for all parts/components involved.
As per your request.
This motherboard?
https://download.gigabyte.com/FileL...1002_e.pdf?v=59cc1f2d26534159d27e2e7d71214a42
Do verify that I found the applicable User Manual.
No specific answer. However, read through the User Manual and pay close attention to supported configurations.
Section 2-8 may be the most relevant.
What you will need to do is sketch out some diagram(s) of connections/configurations that did not work and the configuration that began to work.
Likely that once the correct physical connections were made (which can include undoing something that is or was not correct) then Windows was able to load all of necessary drivers etc. in accordance with the necessary configuration settings.
And the wireless worked.
Reactions: MajorTom308
First thank you for your suggestion, and that is the right manual, but you got me curious so tested each SATA port with the optical drive. It seems that the drive and WiFi are compatible with each other in ports 0,1,3. But as soon as plugged into port 2 both the drive and WiFi stopped working. So through deduction, it seems there is a manufacturer defect of some kind in port 2. Been building systems since 1986 and always there are a few "bugs" to figure out. 👍
