Hello everyone,
I'm currently building a new pc. Motherboard is Gigabyte Z390 UD, GPU is RTX 2080 SUPER, CPU i9-9900k and RAM is 32 GB DDR4 3600 MHz.
For power connections on the motherboard, there's both a 2x4 12 V connector, and a 2x2 12 V connector. The PSU I have (850W from Corsair, btw.) does not have the cable for the 2x2 12 V connector, so it's only connected to the 2x4 12 V connector at this point. Don't I need a 2x2 12V cable as well, given the other components I have installed?
The system won't really boot - the PSU fan does not even spin, it only moves very momentarily and stops, and then after some seconds the RGB RAM begins to illuminate. At this point I suspect that that happens because only the 4x2 12 V connector is connected, not the 2x2 12 V connector as well. Do I need a cable for the 2x2 12 V connector? If yes, where can I buy such a cable?
Greetings,
Anton Vind
Greetings,
Anton Vind
