Motherboard: GA-Z77X-UD5H(rev. 1.1)
Bios: F14
Serial/N: 133000021345
VGA Brand: EVGA Geforce GTX 670 FTW
CPU: Intel i7-3770k 3.5Ghz (3.9Ghz Turbo)
Memory: 4x 8GB DDR3 1600
Corsair Ram Model Number: CMZ32GX3M4X1600C10
Power Supply: 650W
Issue: Please note the System Configuration Specifics listed. //
This is a brand new system, all new parts. During the initial system build, I installed all four DDR3 memory modules. The system would not boot, through further analysis I read the LED Error on the motherboard, it started with 15, and would quickly flip to 51.
When reading the manual I determined that it was memory related, after removing three modules and only have one in the DDR3_1 socket, the system booted properly.
To test if it was a memory issue, I tried each memory module in DDR3_1, all with successful boots. Upon confirmation that I did not have a bad memory module, I attempted booting with a module in DDR3_1 and DDR3_3. Trying this resulted in the same error. Further testing was with memory modules in DDR3_2 and DDR3_4. Again, same 15 > 51 error code.
Others have suggested that my Power Supply may not be sufficient?
I also noticed a new beta bios that was supposed to increase memory compatibility?
Please advise any further analysis or debugging that I can do.
Bios: F14
Power Supply: 650W
