Hello once again.
I have run into a problem concerning my tubing sizes and the sizing I need for my fittings. My glass tubing is 16mm x 12.6mm (OD x ID) according to mayhems site (I am using mayhems 16mm glass tubing) which is the perfect size for what I need. (I already have the tubing)
The problem is I cant find any Bitspower fittings that are 16mm OD, I can only find 11/8mm and any other size I find such as 19/13mm obviously wont fit but the range is incredible small.
Where can I find a wide range of Bitspowered fittings for 16mm OD tubing, keeping in mind I'm from the UK and I don't really want to pay for the import charge as its quite expensive.
Cheers.
Cheers.
