Glass Water Cooling Loop
pfirepfox
38
Hey Everyone,
Just over a year ago i setup my custom water cooling loop and i used the normal plastic tubing to complete it. I am now unhappy with the look and i know that i can produce a much more appealing machine. I however have compression fittings and i do not know if i can use them on glass or any other hard tubing. My setup as follows
fittings: https://www.ple.com.au/Products/617814/EK-G14-12mm-716-ACF-Blue-Compression-Fitting
tubing: https://www.ple.com.au/Products/620831/Mayhems-12mm-Borosilicate-Glass-Tube-50cm
Will this work?
Thanks in advance
I thought that might be the case. Thanks for clearing it up
