Glidos: Problems w/ TR1 Voodoo Rush Patch (and Other Patch..
G
Guest
Guest
Archived from groups: alt.games.tombraider (More info?)
I seem to be having this problem: For some reason, if I use any patch to TR1,
including the Voodoo Rush patch, it shuts down just as it starts. Result: I
can't use Glidos. Is there some way to make it work with an nVidia GeForce 4
FX 5200 chipset?
Also, would it be simpler to go into the sound setup for TR1 and input the
settings manually to get the sound to work? If so, what settings would I need
for nVidia nForce? Could the creator of Glidos add audio settings to the
program to make it work?
i would say that you should input your sound settings manually. To check the install of
Tomb Raider 1, first make sure it runs normally with out glidos.
then i suspect you will have to follow this advice"
TR1 works on all versions of Windows. There are instructions, and an installer,
at http://www.glidos.net, which cover use with or without Glidos.
** No Fate **
cheers,
dracman
Tomb Raider: Shotgun City
http://www.smokeypoint.com/tomb.htm
http://www.smokeypoint.org/traod/traod.html
**savegame editors all versions Tomb Raider & TRAOD godmode
http://www.smokeypoint.com/tr2code.htm
http://www.smokeypoint.com/tombraider1/tombraider1pictures.htm
http://www.smokeypoint.com/3dfx.htm
http://www.smokeypoint.com/banshee.html
http://www.smokeypoint.com/My_PC.htm
http://www.smokeypoint.com/tomb2.htm#Tova
** GTA III vice City Character MOD
http://www.smokeypoint.com/uzi.htm#gta3
NFS: drive at the limits of tyre adhesion ! snag Lara's Croftraider IV sports car ! !
NFS3:NFS4
http://www.smokeypoint.com/3dfx.htm#raider
http://www.smokeypoint.com/3dfx.htm#blondstranger
NFS:HS - Reg method to add your d3d card to NFS:HS
NFS III - Reg method to add your d3d card to NFS:HP
Mad Onion - 3DMark 2001 and 3DMark 2001se -
{not the Pro} 4x4 Missile Launcher Truck Secret Game Demo screen snaps
(and secret password)
http://www.smokeypoint.com/3dmark2001.html
http://www.smokeypoint.com/glidos.htm
http://www.smokeypoint.com/medipak.htm
http://www.smokeypoint.com/tombraider1/tombraider1midaspics.htm
** Win2k and winXP hi-res with TR1
"Paul E Kiefer Jr" <pkieferjr@aol.com> wrote in message
news:20040505152840.23604.00000505@mb-m12.aol.com...
: I seem to be having this problem: For some reason, if I use any patch to TR1,
: including the Voodoo Rush patch, it shuts down just as it starts. Result: I
: can't use Glidos. Is there some way to make it work with an nVidia GeForce 4
: FX 5200 chipset?
: Also, would it be simpler to go into the sound setup for TR1 and input the
: settings manually to get the sound to work? If so, what settings would I need
: for nVidia nForce? Could the creator of Glidos add audio settings to the
: program to make it work?
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
> an nVidia GeForce 4 FX 5200 chipset?
Isn't that a contradiction of terms?
JW
i got suspiscious when he said "chipset".
** no fate **
dracman
"Dublevay" <duble@byNO--SPAM.co.uk> wrote in message
news😱Wzmc.3984$CM6.38989888@news-text.cableinet.net...
: "Paul E Kiefer Jr" <pkieferjr@aol.com> wrote in message
: news:20040505152840.23604.00000505@mb-m12.aol.com...
: > an nVidia GeForce 4 FX 5200 chipset?
: Isn't that a contradiction of terms?
: JW
