glitched fan curve?
endermanac
71
after messing with the fan curvs on msi afterburner and controlling it ehen i disable everything and put it to its defaulse auto the fans wont turn on i tryed reinstalling msi afterburner and doing a clean windoes install with new drivers n stuff ans still glitched
(it wont turn on fans not rven at temps higher then 65°C)
If it is a newer Nvidia GPU 9XX or 1xxx series GPU then the default fan curve is designed not to turn the fans on if the GPU is below 60c. So if that is what you are talking about then they are not glitched. Hope that helps.
