Going about a system boost!
esenfur
24
Hey there guys,
Back with yet another question.. Im looking to boost the systems performance.. Currently been getting lag in games n etc for no apprarent reason too!
Heres the spec:
Intel i7 3770k @ 3.5GHz /w Noctua NH-D14
Asus P8Z77-V Pro
16GB(2x8) Lowprofile Vengenace
Asus GeForce 670 2GB
Questions:
Networking - I have multiple programs installed to get the wifi up and running. Im running off on-board provided, Network iControl is turned off in Asus Suite.. Just not sure which is safe to remove and which 1 I need to keep.
Performance- Ok, going about boosting the CPU.. Can I use this Asus Suite, or bios only? Is there a template of another persons OC, in which I can copy(not very skilled at OC)
Some fans I bought are higher than 900 RPM, but thats all it will reach..
How can I OC GPU.. know whats best for games to run at other than "oh lets click the lowest setting in drop down box" TXAA and AA and the otehrs confuse me :s
thanks for help!
Might start simply by raising the CPU multiplier to 40, with many 3770Ks thats all that's needed for a 4 OC, then would check the internet (google 3770K P8Z77-V Pro OC guide
